Thanks for all your help Frodo. I really appreciate it. I've attached two pictures of possible layouts. I know they're not the best but hopefully they'll illustrate what I'm trying to say. They used to have the tub wet vented right into that wye that ended in the side outlet off of the closet bent, which I am hearing is a huge no-no. so I wasn't sure if the tub would still be wet vented if I left those two lines together. There's not a ton of play vertically because of where they cut the joists, but if I can run over to where the soffit starts, then I have more room and can fix the cut joists as well. either way, what fitting can I use to start the vent for the tub? It's pretty much touching the underside of the subfloor already, so would a fitting on it's side run over to the wall, then a 90 up to the roof work? Thank you so much for the help.
