Smart arse!A neighbor probably did it.![]()
Probably ex cop neighborzSmart arse!
Yikes. This is an EXTERIOR wall & they cut huge chunks out of the studs near the bottom plate.
View attachment 42295View attachment 42296View attachment 42297
Also charred stuff pretty badly & no nail plates in sight on the electrical.
View attachment 42298View attachment 42299
I'm no expert, but this doesn't look right. Should the solder be dripping down like that?
View attachment 42300View attachment 42301
At the end of the day it's functional and allways better to have a full joint we're soldering
I doubt it- the sole has a butt joint between two joists and the lumber that goes across the joists looks like blocking, but it's still terrible practice even if it is common. My house had some similar stupidity before I fixed it by removing the old pipes and scabbing new stud material to the others- mine was in the wall between the kitchen & bath, so the studs were attached edge to edge, but they didn't use wider lumber at the bottom. My house was built and remodeled by idiots.I am not a expert, but i wonder if you have a structure support issue now.
They definitely had a full joint on this jobAt the end of the day it's functional and allways better to have a full joint we're soldering
