Have fun cutting that cement board!
Thanks. I am keeping notes and when you suggested 1/2" I priced it out. Does the cementboard have a rough texture on the surface? Is that why it would look bad if painted?My first thought is the thought of using 1/4" concrete Durock cement board, which is just too flimsy. If you are using Durock, go 1/2" minimum.
I'm wondering that too. Can thinset be painted? I might just spread thinset over any exposed surface. Would be simpler to do cementboard all the way up instead of trying to merge with drywall which requires different screws and mortar. The Durarock Cementboards are a little under $10. The purple drywall is ~$22. So cementboard is cheaper.Yes, it would look horrible
BUT
I'm wondering if you can use drywall mud on the Durock to make a paintable surface. Similar to Venetian plaster?
Yes. We can see where they are nailed to the studs & feel that its more solid there. The wall panel next to my toilet peeled back a bit and I can see the same type of boards but without any damage. I'm hoping that was the only section that had damage.Do you have 2x4 vertical wall studs behind those termite infested horizontal boards?
