The sink has a small chip in the bowl and some cracks, but it still works. I used the internet to find cleaning solutions. Vinegar and baking soda seemed to work the best.
Before
After:
I have had some issues with mice chewing some of the spots on the vinyl flooring so I will have to cover those spots. I stuffed steel wool into mouse holes and may need to add some caulk or something else to secure it better.
The shower is a complete mess not just bc of the stuff in it, but because the wall panels are disgusting and falling off. They were glued to printed wood panels that had murals of ducks. The wall panels are delaminating.
What still needs to be done?
*Fix/reattach hinges to vanity door & vanity
*Sand & do another coat of paint on vanity
*Remove bare wood trim and replace with nicer trim
*Smooth floor out better in some spots
*Replace switch for vent/light/heater
*Replace GFCI oulet
*Install vanity light
*Sand & paint window trim & door
*Frame out and install new mirror
*Empty out tub and find good spot for chest of drawers
*Get (or build) & install tank topper cabinet
*Install cementboad and new shower walls
*Install new shower trim and showerhead
*Install wainscoting and baseboards
*Clean up tub and patch gouge in porcelain
*Eat chocolate and take a shower
The PEX is roughed in for the shower-- access is in the adjacent hallway closet. I will be going with Delta Lahara trim with a pex crimp Multichoice valve.
Moen Magnetix Engage showerhead combo
Delta corner grab bar shelf
Moen Monticello tub spout:
I think I've picked my shower surround. I may do some hardiboard backer that is waterproof (purple board isn't suitable for glue-up surrounds according to the manufacturer). So, I'm looking at the Mustee Durawall 350.
MUSTEE Durawall 30 in. x 60 in. x 58 in. 3-Piece Easy Up Adhesive Alcove Bath Tub Surround in White 350WHT - The Home Depot
That will allow me to install the corner grab bar.
I will add blocking in case I want to add more grab bars later.
I'm thinking of adding some suction cup shelves above and below the grab bar shelf and adding a tension rod shelf thingy to the other corner. I may have a shower caddy as well.
I'm seriously thinking of getting some sort of soap/shampoo dispenser that mounts to the wall via adhesive or suction cups to avoid having bottles in the shower that can fall/get dropped. I use a combo of shampoo & conditioner and bodywash/facewash. So I should only need 2 dispensers. I want to use the existing shower curtain tension rod at the back of the shower so I can hang hooks on it to hang up things like back scrubbers.
I'm thinking of using instatrim for where the walls meet the tub (my tub does not have a flange/lip). I'm thinking of making some sort of lip but not sure if it is necessary. I will probably use some flashingspanning the joists behind the backerboard.
So, any suggestions?
