wpns
When you turn on that breaker and plug in a lamp, do both outlets work?
It is a recently built, three story residential building/retirement complex. I rent here after becoming a widow and selling my 122-year-old home. I believe they began leasing the units in late fall of '22. I have been here since May '22.How old is this house? Not only do you have a claim against the builder, but I would say you have a claim against the inspector, because it’s not just “not right”, it’s actively dangerous.
Oh yes, would that one would show up! Was supposed to be here this week, so far nobody! The office has called the vendor AGAIN earlier today, left a message, but no response yet. I have both appliances unplugged, breaker off, and of course, not trying to use either the disposal or the dishwasher that shares the outlet.Yeah, open neutral at least, I bet plugging in two identical lamps would show them working, but any imbalance would blow one of them out, and you appear to have other things on at least one of those circuits, so don’t do that.
Seriously, this is actively dangerous, let an expert deal with it.
Any master electrician can look at this and tell probably instantly what needs to be done based on the symptoms. If you have to wait much longer, I would start thinking about bringing one of your own choosing into it. Then file in small claims for the cost. I know that’s a hassle but you would most likely recoup the money spent.Oh yes, would that one would show up! Was supposed to be here this week, so far nobody! The office has called the vendor AGAIN earlier today, left a message, but no response yet. I have both appliances unplugged, breaker off, and of course, not trying to use either the disposal or the dishwasher that shares the outlet.
Actually, you don't even have to file a small claims suit to recoup your money. Just send the office a registered letter stating that you've waited long enough and will be bringing in an electrician yourself, and that you will be deducting the cost of that electrician from your rent. The law is on your side in this matter.Any master electrician can look at this and tell probably instantly what needs to be done based on the symptoms. If you have to wait much longer, I would start thinking about bringing one of your own choosing into it. Then file in small claims for the cost. I know that’s a hassle but you would most likely recoup the money spent.
Curious question: if the lamp is two pronged but that outlet is three pronged, would I have to have a three pronged lamp to have it light up?Yeah, open neutral at least, I bet plugging in two identical lamps would show them working, but any imbalance would blow one of them out, and you appear to have other things on at least one of those circuits, so don’t do that.
You know, I have definitely thought of doing exactly that, since it's STILL not resolved, and maybe then MY apartment would be made safe...but I'm suspecting safety issues building wide! I've started quietly surveying my neighbors to collect a bit of data and asking some specific questions if they mention anything electrical.Actually, you don't even have to file a small claims suit to recoup your money. Just send the office a registered letter stating that you've waited long enough and will be bringing in an electrician yourself, and that you will be deducting the cost of that electrician from your rent. The law is on your side in this matter.
Totally agree with both of you! I am ONLY relaying the pictures taken from the suspect outlet, not doing any diagnostics down there myself! Gathering all the information I can, so when the electrician shows up, I'll have some documentation to share. My diagnostic skills are NOT electrical, but medical in nature. In the meantime, everything remains unplugged, and the breaker off. I did, however, by myself, test my new circuit analyzer in the already tested correct outlets, ahead of the "diagnostician" who came with more equipment, voltage meter, etc. With the disposal breaker on, and both appliances unplugged, the bottom outlet indicated zero voltage. Don't have a picture of that.What MicEd69 said. Well that analyzer can detect certain common wiring problems, this is not a common wiring problem, and you need to stop diagnosing it yourself.
I would say nothing to the electrician. In my experience, a master electrician will take five minutes to figure it out. He or she won't need you to say a word. It won't end up being rocket science.Totally agree with both of you! I am ONLY relaying the pictures taken from the suspect outlet, not doing any diagnostics down there myself! Gathering all the information I can, so when the electrician shows up, I'll have some documentation to share. My diagnostic skills are NOT electrical, but medical in nature. In the meantime, everything remains unplugged, and the breaker off. I did, however, by myself, test my new circuit analyzer in the already tested correct outlets, ahead of the "diagnostician" who came with more equipment, voltage meter, etc. With the disposal breaker on, and both appliances unplugged, the bottom outlet indicated zero voltage. Don't have a picture of that.
Yes, open neutral will do that. But the 'analyzer' is just three neon bulbs, so it indicates 'more than 90 volts' with a very high impedance, and appliances (when on) are a very low impedance, so they don't really tell you much more than some subset of pass/fail for common wiring problems. If you built one with three 100W incandescent bulbs, you'd get a very different 'reading', and it still wouldn't tell you much more than "Something is seriously wrong, get a professional to straighten it out."With the disposal breaker on, and both appliances unplugged, the bottom outlet indicated zero voltage.
I would probably agree with your advice, but every person that's come SO far has asked me, "tell me exactly what's happening." Maybe the electrician won't ask, but I have been blown off enough times thus far, that I'm damn gun-shy of trusting anybody. I am a Pitt Bull for the truth, when I need to know, and in particular, when and if it involves my safety and/or the safety of others within my circle of concern. Also, can you define master electrician? is that a journeyman, a licensed electrician, or what? Thanks!I would say nothing to the electrician. In my experience, a master electrician will take five minutes to figure it out. He or she won't need you to say a word. It won't end up being rocket science.
It depends on your jurisdiction, a master electrician usually worked as a journeyman for X amount of years before moving on to apply and test for license as a master. There are a lot of guys doing electrical work and claiming to be electricians, I will only work with licensed master electricians, that way I know they have the experience and diagnostic capabilities.I would probably agree with your advice, but every person that's come SO far has asked me, "tell me exactly what's happening." Maybe the electrician won't ask, but I have been blown off enough times thus far, that I'm damn gun-shy of trusting anybody. I am a Pitt Bull for the truth, when I need to know, and in particular, when and if it involves my safety and/or the safety of others within my circle of concern. Also, can you define master electrician? is that a journeyman, a licensed electrician, or what? Thanks!
You can tell them what is happening, but a well qualified person won't need to know about a bunch of tester lights etc. In my opinion, it muddies the water and for an experienced electrician, they won't need to know about all the lights and what you have done thusfar. It's like hiring an experienced plumber and then sharing your interpretation of plumbing codes.I would probably agree with your advice, but every person that's come SO far has asked me, "tell me exactly what's happening." Maybe the electrician won't ask, but I have been blown off enough times thus far, that I'm damn gun-shy of trusting anybody. I am a Pitt Bull for the truth, when I need to know, and in particular, when and if it involves my safety and/or the safety of others within my circle of concern. Also, can you define master electrician? is that a journeyman, a licensed electrician, or what? Thanks!
