sinks are 42 inches apart, and they are joined in the middle using 1 ptrap. Wrong as it may be now, Installed and passed back in 84. No flow problems (Unless wife has gummed it up) you might be thinking, why is that one faucet turned to the side... well SWMBO wanted it that way. The only odd part is when soap creates foam, the other sink will gurgle and depending on how soapy she gets, some foam will actually appear in the other sink. (There is a diverter in the t between the sinks, but it gets past it) ( no gurgle without the foam)
So would these really need seperate, p traps ? And if so, how would you run them ? Towards the back of the cabinet and then over ? Or just along the current path. (Swmbo would not like that. )
As you can see the drain goes down within the cabinet and the vent is in the wall. Double floor joist under that wall.
