I feel like I am in a Twilight Zone of my own! The wife and I binge watched several episode so the 2019 incantation of Rod Serling's classic television series. After doing so, I decided I'd try and do a little troubleshooting on our relatively new GE washing machine. The machine has developed a slow "drip drip" leak on the cold-water side of things and I was thinking that maybe I could "shock" the valve back into working by using the auxiliary water dispenser on and off rapidly by setting it up and opening and closing the lid quickly which starts and stops the water flow when in the dispensing mode of operation.
I ran a quick "Drain and Fill" cycle which pumps out the water that I have previously put in and then spins things dry for about eight minutes. To my horror, after that short cycle was finished, the closed lid to the washing machine was absolutely covered in crap and the inside of the tub was also filled with much of the same cruddy material. Yes, I can probably understand how the stuff got into the bottom of the tub but I am unable to fathom how that material exited the tub and made its way to the top of the closed lid? I suspect I am living in the twilight zone but if any of you have any idea how the stuff got out of the tub and onto the closed top, I'd appreciate your thoughts. A pic of the crud on the top is attached.
