Just moved into a new apartment, I have this in my utility room and want to install a washing machine.
The sink is mounted on metal bars protruding from wall, so changing the sink for a laundry sink for drainage is difficult In the photo you can see the grey drain bung in the floor. I was thinking to create a system according to this photo I found online, with an AAV up from the waste drain on the floor, going as high as possible (where VTR is in the diagram), P trap coming off to the side and then standpipe for washing machine.
I am a complete layperson when it comes to plumbing..
Questions:
1) Would this general setup be ok ?
2) if so, what diameter pipes should I use ? Bit confused how I would connect for example a 2inch pipe into a floor drain (perhaps there is a flange for this ?)
Thanks in advance.
Will
Questions:
Thanks in advance.
Will
