Tub Overflow Leak
randomsd
Jan 23, 2025
San Diego CA
I'm looking to remedy a leak I have a in the overflow portion of my tub. Most of the water damage (image attached) from below came after a bath and prior owner, so now we only use the tub for showers. The most similar setup I've found is the Watco Innovator (image attached) online. It requires a washer behind the tub, star nut, and cover. Water gets between the star nut and tub. If i tighten the star nut too tight, I can no longer fit the cover. I think that would mean that the washer behind the tub is worn out. I do not have access to the plumbing to replace that washer.
Is there anything i could do to remedy this, without access to the back? I think even if I did cut open drywall for an access hole, getting a washer back around might damage more plumbing due to having to pull the pipe back out of the tub.
Could i just tighten the star nut and ditch the cover, which is not aesthetically pleasing? Add a rubber washer between the tub and star?
Any general advice would be greatly appreciated!
    370.3 KB
    445.9 KB
    389.5 KB
    222.3 KB
    171.3 KB
    754.8 KB
Normally on a tub overflow the washer you show is thicker on one side to make up for the slant on the tub, I think I would try 2 things, silicone caulking on the face of the foam gasket facing the tub then a little more
Under the black nut, after fastening the chrome cover you could put a bead of silicone around the chrome cover
The 2nd would be plumbers puddy
Except for the chrome cover silicone there
Might not be a bad idea to open the ceiling it's wet anyway you could see up there so you could test before you start,
Then after things dry(silicone).
