Newbie posting here!!! Need mono flow heating system info please
Abbazabba66
Jan 21, 2025
NH
Hello all, first time poster here so I’ll try to keep it brief and not inundate yalls with too many questions right off the bat. Wife and I have been in our 3BR cape since 2013, forced hot water baseboard 3 heating zones taco circ 007’s, 1 addl 007 for triangle tube water heater, Utica boiler (age unknown) Beckett oil burner. Just replaced leaking HyVent on top of valve on top of expansion tank. I shut boiler fill valve from well, drained the boiler some from bottom valve at floor to relieve some pressure, unscrewed the old HyVent holding a rag on the opening, little bit of water sprayed out then put new unit in right away. Filled boiler back up, started up and seemed ok. Pressure will not stay around 20 as usual, keeps creeping up to 25, even 30 at one point so I drained some water out as I was afraid of the relief valve letting go. How can I get the pressure to stabilize? All baseboards in house are fine/warm. Any instructions on how to properly drain/fill/bleed these systems in order to replace parts without having these pressure issues. Thanks in advance. I can post pics upon request.
Is the boiler auto feed new or old, if your boiler feed keeps feeding it's gonna make the pressure creep feel the cold water line ( watch the pressure gauge if the water keeps feeding in id start at the boiler feed
In October of 2020 I replaced the auto feed, expansion tank and hyvent above the tank (same one I just replaced). Feel the pipe after the auto feed I am assuming? Will get back to you on that but do you really think I would only get just over 4yrs on that autofill? Also I’m in NH and we are having a nice cold snap 0 at night, teens during the day, boiler is running a lot more, doesn’t that have a big effect on pressure changes?
Hey Geofd,
So to answer your question if the pipe was cold. This morning went down checked pressure after a heat cycle and was about 27-29 but fill pipe was not cold. I drained some water to ease the pressure, pipe still not cold. About a minute later when another zone called and turned the boiler back on the pressure dropped by about 5 then the autofill started and pipe became cold. Any info/thoughts would be great! 👍🏻
Feel the pipe before the auto feed most times when it's feeding in you can also hear it, if you have 2 floors above (,the basement pressure should be around 15+ an you adjust the pressure feeding into your boiler usually there is an adjustment on that
Thank you! Removed the cover for the schrader valve on expansion tank cuz I wanted to check charge and water started pissing out a bit. Was able to get gauge on there and it was about 12 but plumber friend of mind said change the tank. 🤷🏻 I did so and still in the mid 20’s consistently for pressure. He thinks the gauge might be bad? I did melt a small piece of the clear cap with a torch many years ago?!?
