Tom the Elder
Backfilling a deep hole while avoiding a dip or a bump years later is mostly either difficult or expensive.Another way to fill the hole and not leave a long-term hump or depression is to surcharge it with an additional 3 foot of dirt. Then after a few months, you can remove the excess dirt and the ground will be level.
No, it doesn't take 30 years for the ground to settle, but it can and often does take 2 to 5 years depending on the soil. If you go around to a new subdivision a year or so after everyone moves in, there will lots of low places over utility runs.
The expensive ways are filling with concrete or flowable fill.
Compacting backill is difficult in such a small, deep hole. You need to compact it to at least the density it would achieve if just left to settle for years, i.e. what you would get if you just dump soil in and let it compact under its own weight. Any less than that and it will settle over time and leave a dip.
Compacting with a surcharge load can absolutely work. Unless the original soil was VERY loose, that is essentially what you get when you backfill with just the excavated soil - like a classic grave mound. Adding more soil than was excavated can speed the process. However, in many cases even just the excavated soil will never settle to be as dense as the in-place soil and a mound will remain no matter how many years you wait.
Another DIY way is soil-cement. Mix about 3-5% cement into the excavated soil then tamp it into place in thin lifts (compaction by hitting with the end of a 2x4 would be tedious but cheap and effective). The cement adds strength to avoid settlement. Discontinue the cement above whatever root depth you anticipate for that areal.
