Single handle kitchen faucet, cold water flow reduced
concernedbiological
Feb 20, 2025
Usa
Hi
Have a single handle Kohler kitchen sink faucet
When handle is down/towards the hot works fine
But up/away for cold the stream is a trickle
Worked fine until the valves were shut off to diagnose a separate issue. Valves were opened back up and now this behavior
Any ideas what I can check?
The only other valves below the sink is the valve for the dishwasher.
Thanks
we start by connecting flex to angle stops and run into a bucket to confirm you have perfect flow.
Next is working way through the valve.
you may have a clogged port and replacing cartridge after confirming flow at the ports.
