Swept and vacuumed until shopvac clogged. Still need to clean more thoroughly. Vacuumed on top and rolled it up to vacuum under. Found a couple mouse holes I need to plug (one near bathtub corner & another on the wall broom was leaning on). Mice chewed the edges of the vinyl in those spots but fortunately those places will be covered or cut off.
As you can see, this area still needs work. The filthiest part will get cut off. It was hanging over into the bedroom over the carpet. I'm going to have to see if I can carefully pry the carpet edge up to shove the end of the vinyl underneath and then tap carpet back down. I don't plan to pry it up too much. Gonna perimeter tape at corners, doorway, around toilet, and on toekick. I might run it up the toekick a bit if it will cooperate.
I found my flooring tape. Hooray. Debating whether I should let it sit and settle a bit more and flatten it more before taping it down or just going for it if my body will cooperate. I know I'm going to have to wash dishes and cook dinner tonight and hoping I'll have the energy.
I have to keep the door closed to keep cats from running in.
