I've discovered that I need some sort of magnifier for the measuring tape. Mine has the numbers on it but I read them- they look like ants. Send help! LOL.
I want to build a box similar to the one I need to put under my tub to support the cut joist but for this one I want it under Mom's toilet to reinforce the subfloor. I should have enough leveling mix left over to patch the surface layer if need be. If the floor can be repaired I will put a vapor barrier over it (hey, it saved the subfloor in my bathroom) and put the plywood on top. It will raise the height of the floor 1/4" overall but that shouldn't be a big deal. But, I want to add some 1x2 furring strips on top of the 2x4s when raising the countertop. I'm still debating what laminate to put on the counter or if I should try painting it. I want to replace the fugly sink. There's an Aquasource 19" round sink with overflow that looks decent. It's about $39 but I've seen complaints of the holes not being drilled properly so I'm on the fence. I don't want to spend too much on it but want something at least 6.5" deep. I'd found one I really liked that was 8" deep inside but it is no longer available.
I need at least 7'5" of sheet vinyl (and that is bare minimum) to span from the shower to under the vanity's toekick. Will need at least 6'2" to cover from the side wall to the door threshold. I believe the sheet I have is 8'x12' but I'll have to confirm. I want to save enough that I can have some leftover to cover the guest bathroom. I think if I have the 8' part span the 7'5" area and then cut the 12' part to 6'5" I should have enough for both rooms. I pretty much need almost 5'5x5'5" for the guest bathroom.
Working on a Sketchup model of mom's bathroom.
I noticed that the vanity itself is actually not as long as the countertop from side to side and the gaps were covered with quarter round painted to match the vanity.
In this sketch I've drawn in the 2x4s raising the countertop up. I'd shorten the backsplash to about 2" to not conflict with the power outlet.
I'm still trying to figure out what height to put the showerhead and whether or not it needs to come out from the shower surround wall or if I can get it above. The diverter for it is up fairly high on the showerhead/top of slidebar (I need to check which one) so I need for Mom to be able to reach it while standing without much effort.
The shelves in the bathroom were built by my father out of 3/4" thick boards. I didn't draw in the tp holder yet as I was concentrating on other measurements. He only put the face trim on the lower shelves. Never got around to the upper one and he'd fully intended to add doors to make the shelves into cabinets. If lumber prices ever go down and I can get my shoulder working enough to reach up high enough I can try to finish making the cabinets.
In this sketch I also sized the shower space to 60"- it's currently 59". I looked inside the closet and there is a different wall panel in there so I hope there are some 2x4s or something in the wall that can be trimmed back where the shower walls will go.
In the adjacent bathroom, once I finish getting the leveling mix spread to take away some of the pits, I will use the underlay insulation under some 1/4" plywood and then I'll put down the sheet vinyl. I'll probably do an additional vapor barrier underneath as well just in case. It saved the subfloor before.
I just had brain freeze.
