I need some ideas. My contractor's plumber and the city permit guy don't seem to know what to do and I don't have the money for questionable guys to run up a bill for no reason.
We had a cast iron tub which worked fine for 30 yrs. Then we got flooded and decided to put in a jacuzzi. https://www.homedepot.com/p/America...irlpool-Bathtub-in-White-2732LC-020/202599075 They also kept a shower head working in the tub but added a diverter valve because we added a hand-held shower on the tub itself, for bathing ease bathing pets etc.
At the same time we converted a tiny closet to a 1/2 bath with a macerating toilet since the upstairs sewer drain came down the closet wall. They took-out the copper plumbing at shower and ran pex from shower to new toilet (about 5-6 ft) up across the ceiling of the closet down to toilet, which worked well. Shower worked well but we NEVER TRIED the jacuzzi bath before we got flooded again just a few days after the house was finished.
Overwhelmed with problems...We didn't know until we were tearing out for the 2nd flood, that the jacuzzi had not been installed correctly. The frame was built too high so jacuzzi was not sitting on cement pad - Inspector had not noticed it. It had about 5 inches of air space between the bottom and the cement pad it was supposed to sit in. Since it had an OSB board fiberglassed to bottom, it all had to be replaced again.
This did give the opportunity to install it another one correctly, but it also meant the shower head and water spicket needed to be lowered. A different ?plumber & contractor, tore all out and re-installed a new jacuzzi on a pad correctly and they also decided to install a full toilet through foundation. Then for some reason, they changed out the diverter again and to my surprise, they removed the new pex and RE-installed copper piping at the shower, .....and shower head telling me if I didn't, it would all leak in the wall and I'd have a mess....even though it was all brand new. I didn't believe them but decided if I went against them....sure enough, it actually MIGHT leak! They insisted on changing out my American Standard matching hardware to their Delta. Mine was good grade ...not cheap.
Now....hardware doesn't match rest of bath. Toilet works great. Shower works great. BUT it take 45 min to fill the 50 gallon jacuzzi above the jets. They diverter valve they put in has like 6 or more stops on it and is very confusing with the hot and cold valve they installed. Before it was simple, now it isn't.
Waiting 45 min for your bathtub to fill up is unacceptable. We will fall asleep, get distracted, or forget and end up with bathroom overflow. A new contractor doesn't know what to do. The city permit inspector doesn't either. They say if they try this or that there is no guarantee it will fix it.
I need some help. Can you guys help me troubleshoot this so I don't just through money out the window? With 2 floods, I've already lost so much. Happy to provide any pics needed. Thanks.
