Improperly plumbed A/C condensate.
Aggie83
Supporting Member
Jan 19, 2022
104
40
Rising Star Texas
Moved into my newly-built home a little over one year ago. On Saturday night, we began smelling sewage and could not locate the source after much exploration, thinking maybe a vent pipe was cracked or lose. On Sunday, I called my plumber and he quickly solved the mystery: whoever plumbed the drainage for the central Air conditioner in the attic was an idiot. Wanted some other professional opinions before I call the building contractor and raise heck.
Both the regular condensate drain and the overflow drain empty into the stack for the bathrooms. The drain has a p-trap, followed by a ball valve. So, the p-trap kept the gasses out, until it dried out!!! I guess the ball valve it to block the trap from evaporating during winter, but wasn't told this. Also, where I live in Texas, the temparateres fluctuate 50 degrees F in one day often.... making crawling into the attic to flip a valve really stupid.
Also, since the overflow goes into the sewage system rather than outside the house how would you ever know the main drain was clogged? My wonderful plumber came out of the attic just pissed and I am also.
Tried searching plumbing codes and found nothing. Is this an acceptable way to plumb the drain pan?
Many thank,
Karen
No, that is not acceptable. Condensate line MUST have an air gap to enter a sewer line. Hard piped condensate lines into a sewer line are against the code. It will take me a minute to find it. That installation should not have passed an inspection.
I'm not sure what code you are under, but all codes should be similar on this issue. The appropriate IPC (International Plumbing Code) section is below.
Also, the secondary drain needs to discharge in a place that can indicate the primary drain is not functioning.
For what it’s worth around here in North Carolina on new construction, it is not uncommon to have the primary air conditioner drain for an air conditioner in the attic drain with an air gap into the same drain stack used for the laundry. The secondary or emergency exits above a second floor window. The theory is that if you see water drip through your window you are supposed to understand something is not right, but very few people know this!
thanks to all. Turns out the AC contractor installed this. Said he normally runs the line to the washer box, but could not due to vaulted ceiling. Sigh. Made them replumb both to the outside of the house. We have a concrete wrap-around porch, so the lower will run a lot during the summer. AC guy was worried it would cause green slime. Better that than falling Sheetrock and stinky house in the winter!
My solution is to put a bucket under it and empty it when full. Simple analog solution there!
That’s not going to be a pain in the butt emptying that bucket.
You can directly connect it to above house side of the trap in some cases. I wouldn’t run it into a septic system.
You could’ve piped it into a trap in the attic and added an automatic trap primer. Just giving options
Thanks, TwoWax. I chose the external empty pipe as the simplest method. We spend a lot of time outside (we live on the ranch) so emptying a bucket into the yard is not a problem or inconvenience. If it overflows, meh, don't care. We are in west North Central Texas (hehe) and have low humidity when it's hot.
You da boss
