Mr david's Post. spelled out that a wet vent fixtures shall be within the same story; provided, further, that fixtures with a continuous vent discharging into a wet vent shall be within the same story as the wet-vented fixtures. No wet vent shall exceed six {6} feet (1,829 mm) in developed length
let me explain the term same story, I will type slow so you can understand
the 1st floor and 2nd floor are different story's
AND
the 1st floor and 2nd floor are more than 6' above each other
a residential water closet is with 1.6 gpf per tank is 3FU
so to answer your answered question
NO you can not drain ANY fixtures into the vent from the first floor. You are calling a common vent a wet vent,
and are not understanding what a wet vent is
this is what you have to do in order to add a drain upstairs.
connect a sewage pipe to the existing sewer line BEFORE the vent .
this will entail busting the concrete and tieing into the sewer
