Tankless system goes cold periodically
Venice230
Feb 22, 2025
Florida
I have a tankless system. About once every four weeks, the system goes cold for 20 seconds. There is a temperature blend valve that looks corroded on the outside. I am guessing this may be the issue. Also, what is this valve called? Any suggestions would be appreciated.
Thanks
Rinnai system
RL75i
REU-VC2528FFUD-US (A)
    2.6 MB
    2.6 MB
That looks like the old Microsoft screen saver, did the guy charge by the elbow? 🤣
That TMV looks like it's had a slow leak for a while, I would definitely replace it. I would have recommended replacing or removing it when the water heater was changed. I think they're pointless on a tankless and cause nothing but problems, but they're required by code in some areas.
The house built in 2005 and I am not the original owner. I am assuming there was a regular tank when new and was replaced with tankless sometime after but just guessing.
