When dishwasher is not getting used frequently, the food debris in the garbage disposal can built up to clog the last section of the dishwasher drain pipe, as illustrated in this diagram.
When you use the dishwasher, not aware of this blockage and leave the kitchen or your house, misfortune will happen. Dishwasher's waste water shoots out from the air gap opening, which
1) may not face the sink (air gap cover can freely turn 360° and you might have accidentally bumped it), or
2) the opening is just a plain design, not like a kettle spout which accurately directs water with minimal dripping. As dishwasher drains, the waste water keeps gushing out from this opening, water flows everywhere, no matter your sink is undermount or top-mount. The top-mount sinks usually come with convex/rounded rim, I never saw a model with a high dam around it to keep the water in.
Now water overflows to your kitchen counter, to your hardwood floor, and you are not around to catch this unfortunate incident in time. You end up with a bigger problem.
The alternative to air gap is high loop, that is, to clip the pipe under the cabinet ceiling. As dishwasher's motor pumps hard to drain, the pressure should be strong enough to flush/unclog this type of blockage near the pipe end.
Theoretically, the top of the high loop needs to be higher than your kitchen sink/counter, so that, in case the sink is fully backed up to the rim, the dirty water won't backflow to your dishwater. But how frequently can this happen?
When I compare the chance of blocked pipe end due to infrequent dishwasher usage versus a fully backed up kitchen sink, I found I came across always the former scenario, it happened multiple times to me and my tenants. Yes, it caused water damage to my hardwood floor!
Ideally, I wish the manufactures can redesign the air gap opening to be a spout. So far I haven't found such a model in the market yet.
If you have a better solution, would you please share?
Thank you in advance for reading!
