Undertaker3106
Took several photos for you guys. I was incorrect. The curculator pump photo is included and yes it is pointing down or back towards boiler. The hot feed line and cold return lines runs Tee at the boiler and run to the front of the house and rear of the house. And if you can see in the photos as the lines run and return they branch off to smaller lines and feed hot water and return hot water to the respective main lines. The system is not zoned at all. One thermo in living room. The second floor gets its heat by running the feed and return lines up the inside of the walls and into the room above. Each radiator has a pipe goin in and coming out of it. Reply if you’d like
To see any more photos.
