Aceman
Okay so if you check the video, this is at my daugther's house toilet started to leak--took it off and found that the flange "ring" was rusted out like tin foil. So I remover
The wood rotted away or broke away at one end and also some rotted areas I cleaned up, but otherwise the wood is very solid no need to replace it.
So my plan is to grout around the flange. I will fashion a something on the one end to hold the grout (probably a piece of wooed dropped in vertically with a screw and wire attached then pull it back into place and screew in from the top to fill the large gap. Then I'll fashion something to make a nice "circle" around the pipe and then use grout to make a nice even surface up to the level of the flange upon which to place a new flange ring. I plan to order an "adjustable" ring so I can fit it under neath the plastic flange piece It has a groove where the old rotted ring had been.
Is this a good way to do it? I want to avoid the hassle of cutting out the old flange an reinstalling a new one because it’s glued in and the inside diameter is only 3 inches and I don’t want to go any smaller than that.
