What is this valve called? How can I replace it?
WannabePlumber
Nov 10, 2024
Guatemala
Hello,
I am very new to plumbing, so I an sorry if my question seems silly.
In our bathroom we have this valve which keeps leaking it is very old like it was installed in the 70s now I want to change it but I do not know what it is called and what specification it is.
Can you tell that what it is and how do I change it?
    1.4 MB
    1.2 MB
Looks like the copper is also kind of buried you would have to chip out around the copper and the valve remove and replace
I would not try to rebuild it, it looks to far gone
But I do not know where the valve starts?
Is it the bulb holder kind of thing where the rotational wheel is, is where the valve body starts?
And what tool can I use to safely remove it so that it doesn't damage the GI pipe which is engraved in the wall halfway.
I have a wrench only right now. If I know the whole body of valve and where to twist it by force I may be able to pull out the copper valve safely and replace it.
You need to open up the what looks like concrete to be able to get that valve cut out so it can be replaced. You will not be able to unscrew it until you break the connection on one side. If that is a screwed and not soldered valve
This is probably out of your comfort zone, and should be addressed by a professional
Thanks,
Actually I have spent quite a time tackling this issue with the plumbers in our are , 2 of them but they just put the teflon tape around the thread of the valve which goes into the body which is connected with pipe and say that's it. Which after few days the valve again starts leaking water. So I thought it will be a good start for my DIY kind of first plumbing project. So that I can fix it permanently. Also I will pay more attention to it since it's my own work.
But I talked to a new plumber today and He said there a copper gasket kind of thing which needs to be fixed which is inside the valve.
Let's see.
