What is the thread on my outside faucet.
If you could take a good close-up picture of it and post it, along with an accurate diameter we might have some idea. It could be 1/2 or 3/4 npt, or maybe part of the faucet is missing.
Its
That doesn't look like it. But what is a 'vacuum breaker' and where would it be used? Thanks
Its a one way valve to prevent back siphoning through a plumbing system. The type I’m speaking of screws onto a hose Bibb faucet.
Sounds like it is a vacuum breaker, as others have said. I have replaced several of these in the past. You can purchase replacements at any, plumbing supply, big box store and most hardware stores.
It may or may not have a set screw to hold it in place. The original ones usually don't have a set screw, but are held in place with red Locktite. You need to heat it up with a torch to break the Locktite bond. I never use the set screw that comes with the replacement, as they can be very difficult to remove. Most have a break off screw. It may be in a position that is not accessible with a drill. If you do decide you want a set screw, I recommend a standard Allen socket set screw. I usually just leave it off.
On ours you can, the threads on the faucet are standard garden hose.
Frostproof faucets have it milled into the valve, it’s not an add on. So we’re talking about the add on type. There are different types is my point so you both are correct.
It's been my experience that you can't just remove the part of the vacuum breaker remaining on the faucet and connect a garden hose to it. The threads are different.
My experience is only with the frost proof type. If the vacuum doesn't break, and it freezes outside, there is a good chance that the outer sleeve of the faucet will split when it freezes. I learned that the hard way.
