Water supply pipe joint leak. What went wrong??
Pacifi
Feb 24, 2019
CA
Help please!!
Found a leak in the shower valve water supply pipe joint (cpvc to copper), leaking behind the shower panel into the interior of wall of bath.
Please see video of leak here:
https://drive.google.com/open?id=1RtvFQoFV0uG6X5tSGsVSaXjCxsGcshRi
The leak has been stopped.
Could not attach pictures, so I have added them in a reply to my own post. Please take a look.
The shower valve is not braced.
The supply lines are not clamped.
This home is in California, built in 2009.
I am perplexed this happened. Is it a code violation issue?
Added pictures below.
Thank you!
    1.1 MB
    2.4 MB
cut the cpvc remove the affected cpvc fittings use the exact same new fittings and a coupling
I should have added in my original post, that the leak has been stopped. Made the correction. The plumber I called in urgently did exactly as you said, thank you.
