dts
About 8 months ago I purchased a house (2 stories plus basement) built in the early 1990's with a (functioning) pressure reducing valve. Water pressure coming into the house is about 110 psi and the PRV is set to about 60 psi. Over the past few weeks, I have noticed poor water pressure in our 2nd floor master shower. It is a tub shower combo and the pressure seems so low you can not even get the tub spout diverter to hold to take a shower. Pressure everywhere else "seemed" to be normal, but if more than one fixture is running (i.e. washer and sink), the flow out of the sink is so low you can barely wash your hands.
I ran some tests and with a pressure gauge I confirmed the pressure at (2) 1st floor hose bibs, a 1st floor laundry tub, and a basement level garage hose bid are all at 60 psi. I further noticed that when turning on the hose (if nothing else is running in the house), water "shoots" out of the nozzle as it should, and within seconds the flow slows down significantly (like there was a buildup of water and pressure and once released the flow goes back to the new normal). Once you shut the water off, the pressure builds back up to 60 psi as it should.
Any ideas what this could be? At first I thought it was isolated to the master shower and issue with the valve, but it is appearing everywhere. We don't have particularly hard water- at least not noticeably. I took a some aerators off at sinks and there was no considerable buildup of debris. I could adjust the PRV, but with the pressure appearing adequate, I don't think this will help and just put more pressure on the pipes.
Thanks!
Thanks!
