Plumb_The_Depths
Hi folks. I have a ~2y/o basement sump pump (not 100% on age as we bought the house 4 months ago, but pretty sure it was installed around Nov '19) and just yesterday noticed small amounts of water on top of the pump cover and surrounding area. We have a dehumidifier stacked right next to it (we drain it directly into the sump) that is getting water specks on the side. I circled the areas where we're seeing the water in red in the attached picture. The second picture shows the flex drainage tube that enters our main drain line.
The sump pit isn't full (during this relatively mild and wet Massachusetts winter, the pit has been consistently filled ~1/4 of the way) and the pump is working as we hear it go off a few times an hour. I turned the dehumidifier off last night to rule out any issues with the drainage hose on that and there was new water this morning. Could there be a hole in the flex drainage tube exiting the sump causing the leak? Any insight is greatly appreciated.
