When my softener does a regen, the water looks like this for about 24 hours . It will (mostly) clear up after a couple minutes if I let it run and look like this.
Years back, my pump started to go out and the only sign was because the water got real brown from being churned up inside the well from the pump running 24/7. This pump was just replaced (unrelated reason) so I know it's not the pump this time. The pressure builds up and pump shuts off when it should. My well is 115' and have never run out of water before. Located in NE Ohio.
Do you think it could be from the softener settings using too much water during regen and churning up the well? I have a ton of iron in my well but the water is normally clear. It regens every 1,950 gallons (roughly 2 weeks) and the water is clear as can be once it settles after that first 24 hours.
my setup...
AQUASURE Harmony Series 48,000 Grain Water Softener with Fine Mesh Resin for Iron Removal
100 micron prefilter after pressure tank, before softener.
my setup...
