thezman
I have an interesting problem. I moved into a 5 year old house on 11/01/2008. On 12/25/2008 (yes, Christmas day) the pipe that connects the hot water side of the heater to the pipe going into the house leaked. It was a flexible copper pipe. It leaked at the joint on the wall side (not the heater side). The leak was small, one drop at a time. I replaced the pipe with an identical one.
Some 15 months later same pipe leaked again at the same spot. I replaced it again thinking I will do some research about the premature leak later but I never did.
Now another 15 months later the pipe leaked again at the same spot. So I have replaced it again but want to find out why the pipe only lasts 15 months. The cold side pipe is still the same that was there when we moved in. Any advise is appreciated.
At my old house the water heater was replaced in 1997 and it worked w/o any problems for 13 years.
Thnak you.
Thnak you.
