webmonk
- Joined
- May 23, 2018
- Messages
- 17
- Reaction score
- 2
I've read what I could about this topic and have made a number of changes but still have the problem. I am renovating a house and one of the showers I ran 1/2" PEX from the valve to the shower head. When I turned on the tub faucet it would drip quite a lot from the shower head. I never measured, but I would guess maybe a cup in a minute or less.
I tested without the tub faucet on to take the shower diverter out of play and it still dripped out.
I contacted Delta and as soon as I mentioned the problem they said with no hesitation that it was the seats and springs and sent me replacements. I put them in and the dripping continued.
I read that the PEX has a slightly narrower inner diameter than copper and it allows the water pressure to push the narrower column of water up to the shower head without the diverter engaged. I opened the wall enough to allow me access to the pipe going up to the shower head. I cut all the PEX except maybe 6" that was connected to the valve. The remaining 3' or so was replaced with 1/2" copper with a push connector. I was disappointed to find that this didn't solve the problem either.
Following the same narrower inner diameter of PEX thought, in one final attempt, I swapped the 1/2" copper with 3/4" copper. Still drips out at roughly the same rate.
What am I missing? A problem with the valve? Something else?
I'm at the end of my remodel and need this fixed and the hole in the wall patched so I can get the house sold. Any advice is truly appreciated.
