Hi. I'm wondering if it's possible to patch 2 pieces of wastewater pipe back together via some sort of tape or mesh with epoxy or something along those lines.
Not sure if this severed because of corroded threads or because it was patched to begin with (assuming the black is some sort of tape) by the prior owner and weakened over time.
At the moment I'm looking for a temporary fix or at least something that will keep most of the water moving in the pipe. For now I've just got the 2 pipes tied and bungeed together to close the gap a bit but water still runs out.
I'm not sure that there is enough play or gap between the 2 pipes (maybe and inch or so) for me to put a black rubber clamp coupling. Also, it seems as though the top of the coupling would sit over only a small amount of pipe which would be the octagonal portion of the joint. But if there are any tricks and you think it's doable then would appreciate to hear them. Or any other tips on patching it with epoxy and such. Thank you.
Oh and in the picture collage attached is also what I assume is the top of a big trap for the tub. Weird placement as the underside lip of the tub sits on top of the trap lid. So, I assume I can't actually unscrew the trap without removing or lifting the tub? Weird.
