Definitely NOT ok. Code does allow a straight, low vent under a window if you use drainage fittings (long sweep 90 on the far elbow that turns up.
NO, you cannot do anything remotely like what you show.
Island vents look like this View attachment 43038
Where is the floor level and where is the window bottom. You are allowed to come up as high as possible under the window and horizontal over time the stack.
Or you can run the trap arm horizontally to the vent stack if it is within maximum length requirements.
I'm not sure what breplum was referring to either. Yes, add the red line as sown on your drawing, use wyes at the connections to the horizontal sewer line, use a combo at the connection where breplum said in his drawing, and add the cleanout where breplum said as well.I can't do anything remotely close? I'm having trouble seeing the big difference from what I'm showing... Looks almost identical if I add the red line, as I asked in the post. Again, I'm not showing fittings or even slope.
Thank you! Yes, def trying to avoid AAV.I'm not sure what breplum was referring to either. Yes, add the red line as sown on your drawing, use wyes at the connections to the horizontal sewer line, use a combo at the connection where breplum said in his drawing, and add the cleanout where breplum said as well.
I don't like AAVs unless there is no other reasonable way to vent the fixture. And as you have this layout which will work, I personally would prefer it over an AAV.
