DIYphilly2020
Hello all and thank you in advance for the help. My bathtub faucet has been either providing lukewarm water or running low on hot water fairly quickly the last month or so. I think it was always cooler temperatures than other fixtures in the house, but it has become a problem recently. All other fixtures, if turned all the way to hot, provide "scalding" hot water.
I thought the problem may be the cartridge, so I changed out the Danco 10670 ceramic cartridge for a new one. Still have the same problem. I know the cartridge has a limiter for limiting the amount of hot water coming in, but the limiter is set as far as it will go for hot water. This was the case for the old cartridge as well.
During installation of the new cartridge, I noticed that if I remove the limiter and turn the handle just a little further than it would normally go with the limiter, the water from the faucet actually comes out at the temperature I want. However, the body of the cartridge has teeth on it that do NOT go all the way around, so the limiter cannot be positioned any further than it already is.
Two questions:
1. Other than for safety reasons, I assume there is no necessity for having the limiter installed on the cartridge for normal use?
2. If I remove the limiter from the cartridge and we continuously turn the handle beyond the "normal" rotation allowed by the limiter, will this damage the cartridge in the end? It rotates the shaft of the cartridge maybe an extra 15 degrees.
Thank you again!
Two questions:
Thank you again!
