Rod Macneil
I recently finished up a remodel of a bathroom. Had a plumber do the rough-in for me quite a while back. Now I am trying to complete the finish work to include the tub overflow, but run into this issue where I have threads protruding from the tub overflow hole?im thinking I should be able to unscrew this threaded piece and find the flat surface where I can install the cover, but I don’t want to chew up the threads if I’m wrong? Or crack the pvc if it’s glued in? What do you pros think?
