I'm trying to find the source of a house plumbing water leak. The corner wall diagonally behind a toilet has peeling paint and feels damp just above the baseboard. This is on the first floor of a 2 story house. There is a full bathroom on the floor above, and the toilet flange 'seems' to be centered over the first floor bathroom's wall that has the dampness. The first and second floor walls that the toilets are against are inside walls and do not line up with each other. Does it make sense and is it legit to have the second floor's toilet flange centered over the first floor wall's top plate? The second floor bathroom's tub is on the far side of the room and doesn't get used. The sink is on the same wall as the toilet and all looks well under it.
I'm guessing either a supply pipe inside the wall or the second floor toilet's wax seal.
Any tips on figuring this out? My current plan is to cut a hole in the first floor wall at the damp area and use an inspection camera to look inside the wall.
