Look at how much room you’d have left after you turn the tee on a 45 angle like you say. Look at where that would put the hub of that tee.You could pipe it like that
But I disagree that my idea would not fit
The center to center of 2- 90s like is currently shown is longer than the center to center on 2 -45s
my idea would fit and have room to spare
yours on the other hand is going to be tough fitting the 3x2 combo in with out cutting more
We must be looking at different pics. Have a good one.are you worried about that notched and drilled out old termite ate up joist?
that sob would get cut out, tossed on the floor and new wood installed around the plumbing
cut the 4'' bell reduce off, ram bit the 4'' hub use a 4x3 bushing and march on
if 45 did not fit then use a 22. i roll with what ever works while i am in the hole
