Toilet clogs 3-4x/wk - issue w/toilet itself or further down?
raeyn
Sep 3, 2021
USA
Hi,
About 4 years ago, we purchased one of the Costco Water Ridge 2pc toilets that seemed well rated at the time. We got permission to use it in our apartment as we needed the higher seat.
After we installed it, a few unrelated toilet line plumbing issues came up in the building. A plumbing guy showed up saying that the line was blocked below our unit but was affecting the unit above. The guy augered it and came out with some rubber kids toy, from the apt above I guess because it wasn't ours.
Anyway, we've had ongoing and frequent clogs which are wearing us down. I meant 3 times a week, minimum. This is from regular BM use and normal to light TP use. We finally bought a pro type toilet auger and literally have to use every single time it clogs (it's impossible to plunge this toilet because of the shape of the bowl/hole). Let me say, this has gotten old, especially with ongoing health issues.
FWIW, the clog always seems to dislodge at the very end of the toilet auger's capacity (I think abt 3ft). I would think is likely past our toilet plumbing.
So, I'm trying to figure out:
1) is it most likely an issue with the building's plumbing below our line or
2) a deficiency in our toilet's ability to flush?
We're over this and want to get it resolved. Obviously, we can get maintenance to auger the line but they've done it before & we still have the issue. Also, as I've been trying to learn more about this, I've found some pretty negative reviews saying some of the WR toilets clog incessantly (seems to be completely hit or miss - with folks installing several of the WR toilets and some clog constantly while their others never do). I'm wondering if we have one of those misses.
I'm just wondering, if you came across this yourself, would you think toilet or line? Any thoughts or advice would be super helpful. Thanks so much!
(Please let me know if you need any more info.)
Get a bucket with a couple gallons of water and pour down the toilet to flush. If it goes smooth than your toilet is not allowing the water in fast enough for proper flush
I'll definitely try this but I'm confused. If it goes down smooth, then the toilet won't allow enough water to flush properly? I would have thought that smooth meant it would have allowed enough. What am I looking for if it doesn't go down smoothly? Will it sort of glug-glug-glug? (Sorry for the lack of more pro-type descriptors.)
You probably have an obstruction in the toilet at the outlet of the toilet.
For the amount of times it clogs, I'd do the 2 gallon bucket pour and if there is any stoppage, I'd pull the toilet, inspect, then reset the wax ring.
