@pasadena_commut here are a few other gems from my inspections and observations around here that make little sense.
1.
Electrical Service Panels on the outside of a home. Yes, exposed to the elements. We get torrential rains, freezing temperatures, hot humid summers with triple digit temps and they put the service panel (NOT in a weatherproof NEMA 4 enclosure mind you, but a plain enclosure) Now imagine you pop a breaker or there's some electrical emergency and there's torrential rain. Do YOU want to go outside and fiddle with a panel? Ah, hell no.
2.
No Drip Edge on Gables. Every quality roofing manufacturer recommends it. Best practices contractors do it. But it's not required here on residential roofs, so they don't use it. What happens? Excessive overhang which leads to shingle lift in high winds, and curling of the shingles which leads to failure on the edges. It's the least costly component of a roof or re-roof job, yet they refuse to use it. I've seen inspectors of new homes rightfully point out excessive overhang, and I've seen those roofers have to come back and spend
MORE TIME correcting their problem then if they had used the drip edge in the first place! The kicker is it USED to be code here, and still is for commercial structures. So, you can have one of those older homes on a Main Street now used for commercial purposes, and a re-roof will require drip edge. The residential house behind it? Not required.
3.
Pier and Beam Construction with Masonry Piers. OK, when you have a poured wall foundation, I've seen a small crew stake out the lot on a Monday, excavate Tuesday morning, layout and pour footings Tuesday afternoon, set forms on Wednesday, pour walls on Thursday, remove forms on Friday, and they are framing on Monday. Here, I've seen a crew of five men take three weeks to build a block wall foundation, and build
close to 50 masonry piers within the footprint of the home.
Three weeks. They absolutely LOVE concrete block here and use it for anything they can. It's like they've never seen a poured wall.
4.
Irregular Nasty Crawl Spaces. OK, so you don't "understand" a basement, you don't want a slab and want to build with a crawl space. Fine. Why can't you build a nice crawl space? Why must you have a festering swamp with a sloping dirt floor? I've seen so much nastiness in crawl spaces leading to equipment degradation, vermin and more. Seriously? Who wants to live above that nonsense. You can pour a concrete floor, have it flat, and insulate and seal the walls and poof! Beautiful crawl space...and improved conditions above.
I had mold growing in my crawl space here and within months of moving in had it encapsulated. Expensive yes, AFTER THE FACT. Would have been so much easier to do it correctly from the start during the building process. Now it's clean and dry.
