Vernace
So I have a sump pump in a basin that was improperly installed. The basin is cut straight through the basement slab app the way the the earth below which is all clay. I live about 100 yards off the Hudson River so very low on the water table. That, coupled with an underground stream flowing through my backyard which is only feet away from my sump basin makes for a constant trickle of water (maybe 3-5gph). The current basin is too small to install a plastic drum style basin and I don’t want to make the pit larger because that might hurt the structural integrity of my foundation (not sure about this).
When we get very heavy rain the water crests over my bilco doors and enters the French drain which leads to my basin, both of which get filled with debris which leads to clogs in the pump and a flooded basement.
Here is my plan of attack:
1. Clean out the French drain and basin as much as possible so no debris can get to the pump
2. Installing a secondary sump pump higher than the primary, primary pump also has a backup switch in case the primary switch fails again. Putting check valves on both pipes that lead to the main discharge pipe which runs into the sewer line
3. Cover the bottom of the basin (which is clay soil) with a concrete paver (and screen at the bottom?) to keep the soil from kicking up and clogging the pumps
4. Installing a water alarm in case the sump basin overflows
The main problems are:
1. Sump basin gets soil and debris due to dirty French drain and the basin going through the slab to the soil which leads to the pump clogging
2. Water crests over my bilco doors and flows into the French drain stirring debris up
3. Not knowing when the pump fails
