I have a sump pump that runs alot so have been trying to adjust my switch to just above the water table but below the two drain tile inlets to prevent moisture wicking. I only ever get water coming out of the one inlet after a rain and wondered why the other inlet never gets water coming out. I looked today and can see inside the pipe it actually slopes down and away so the whole pipe would need to be full before water would drain into the pit. I'm guessing when they put the plastic pit in and cutout the holes the one drain tile was to low so they just bent it upwards to fit? After letting the water level rise I can see some what sitting in the pipe with alot of calcium buildup. Is this ok to leave as is? Assuming the pipe is just flat all the way around the footers maybe water takes the long way and drains out of the other end. Would the two inlets be 1 long pipe that goes all around my basement footers or two separate pipes? House was built in 2000 with clay soil. Thanks!
