rickwhoo
What's a good water pressure gauge I should get to replace mine?
Have you ever seen a gauge that looked like mine before?Pretty much anything. https://www.amazon.com/MEASUREMAN-Glycerin-Pressure-0-100psi-Stainless/dp/B07T744FLZ should work fine
Corroded and rusty and leaking with a red background? No, but maybe try something different this time around?Have you ever seen a gauge that looked like mine before?
If water got thru the bladder, wouldn't water come out of the air valve?
I have added air to the tank about 4 times in the 22 years of owning this house. Everytime I hear the pump not cycling normally, I go thru the process of draining the water in it and adding air to the recommended pressure. Everytime I do this I check for water in the tank.Well, yeah, eventually, go ahead and release the air out of the air valve while the pressure is on and see if after all of the air comes out, some water comes out. But that seems like a lot of work to go through, and will make your tank completely inoperable while there is no air in it (you think you’ve seen short cycling now…)
The traditional methods for determining if the bladder is leaking is to notice that your pump is short cycling a lot (which you have apparently already done), you add air to it frequently, and when the pressure is off, you can rock the tank and see if there’s any water in it.
Repair is either replace the bladder (call around and find a price on the replacement bladder, and look in the manuals and see what’s involved in replacing it), or replace the tank. I can’t easily find the bladder part number, so I have no idea what that costs, but the tank looks to be about 200 bucks.
Even 20 showers a day is nothing for the pump. The real use is the irrigation. With just a lawn to irrigate it is still probably lightly used in comparison. Now I have seen some LAWNS that would require the pump to work hard. But they are kept year round and are as big as a golf course.My thinking is, If it Ain't Broke Don't Replace It... It's not lightly used. I water my lawn, wash cars and there's 4 people living in my house. At least 4 showers everyday.
I hate to say this but most home inspectors won't know what they are looking at anyway. They will do some little test to see if the water will run for a certain length of time or something, and that is usually about it.I'm currently selling my house and I have a feeling that a home inspection guy is going to say that it needs to be replaced. What do you think???
