I'm having a problem with my moen posi temp shower valve. So I have a tankless water heater, im in the process of fixing the elements right now so i can't actually test for hot water, but I can turn the water back on. I replaced the shower valve as it was giving me issues. Here's the problem though, I get full hot water at the bathroom sink but not at the shower. When I turn off the cold water isolation valve for the bathroom at the header I get pretty much a dribble of hot water from the shower (which isn't enough to turn the water heater on as it senses for flow), but I get full flow of hot water at the sink. With the shower valve still at full hot I turn back on the cold water isolation valve for the bathroom and the shower is flowing fully and turns the water heater on, even though all I did was turn the cold water back on. This confuses me so much , how could turning on cold water affect the flow of hot water. I already have the shower valve stopper set to max heat. Im not sure if this is normal or not. I guess I could try and clean the cartridge but the while valve is brand new.
