We just bought a house 3 weeks ago and have just inhabited the second floor with our children. When the three of them took a shower last night I had water dripping from the ceiling on the first floor. Upon inspecting the shower I found that when I took off the drain strainer that some silicone sealer was loose laying in the drain. After I pulled the silicone sealer out I found a very weird connection. It is a plastic formed shower and when you pull up the screen there's a 4 inch round white plastic fitting. In the hole of the fitting Loosely fitting is a 2 inch piece of Plastic drain pipe. So there's about a 32nd inch Gap between the pipe and the fitting/donut.
I am not in a position to remove the shower. What could I use to repair that Gap or fill it in?
