WallyWater1
Hi everyone,
I am having a serious issue with my newly remodeled guest house shower. See attached pic.
Every day that I check by turning on the shower, sewer smell comes out from the new shower drain. It also happens when I flush the toilet first, before turning on the shower.
The smell goes away after a couple of minutes, but I still hear from the shower drain all of the water rushing out when the toilet gets flushed, or even the sinks are used.
I have done my best to troubleshoot the issue before we decide to tear up the tile and concrete, at his expense. So far, two independent plumbers told me that the issue is that there is no P-trap.
I want to make sure I have my bases covered before having him start demolition. So here are my questions.
1. How do I confirm with 100% certainty the presence of a P-trap?
2. If there is a P-trap there, could a venting issue be the cause? I did not see him add a vent between the new shower drain and where the old shower drain was.
3. Could the vent that services the old shower drain, and therefore the new shower drain, be clogged and need to be flushed?
4. Finally, if he did not remove the P-trap below the old shower, could the presence of the additional P-trap under the new shower drain create an S-trap situation I have been hearing about, even though they are fairly far apart?
I am meeting with him tomorrow.
