Hello All,
Our house was build in the 1950s or 60s, but was remodeled 17 years ago (at the time of the remodel, the sewage was completely redone up to the property line cleanout). The contractor used black ABS pipe. See my picture to give an idea of the house sewage system. There are two sewage lines coming from the house and one coming from the guest house. They all joint together into one line that goes out into the street. Overall, the sewage is traveling about 260 feet from the house to the manhole in the street.
Our plumbing does work (meaning toilets do flush, and sinks drain) but it gets clogged/backs up a few times a year. Sometimes, when it backs up, sewage comes out of our shower in the guest house (lowest point).
As you can see in the picture, we have bellies at the end of the driveway near the street (cameras go underwater and water/material is not flowing) and we have a belly closer to the house (camera goes underwater here but the water looks to still be flowing).
Some contractors told us we need to replace all the pipe from the clean out in the driveway to the manhole in the street. Others said it needs to be redone all the way from the house to the manhole in the street.
My fear is that even with all new sewer lines from the house to the street using a rigid pipe like C900 to prevent sags, we still wouldn't be able to get enough slope in the pipe to make a significant difference over out current plumbing.
The other option (instead of new sewer lines) would be calling a service to hydroblast 2 times a year or whenever it starts to back up just to keep the lines cleared.
