Sewer gas smell
Since you say that the smell only occurs when the washing machine is draining my assumption is that when the washing machine drains has so much force that it's actually blowing out the Trap seal allowing sewer gases into the house
have you tried capping of the laundry stand pipe overnite to se if it goes away??
maybe the trap is getting syphoned when you ate using it????????
voleti and i said basically the same thing when the washing machine drains it may remove all the water in the trapletting sewer gas in
after a cycle or the end of the wash use a flash light to see if there is water left in the trap
is that vent tied into the plumbing system or is it an automatic vent
The problem arises only when the washer is drained out. That's what it was originally mentioned in the first post. Saying the smell seems to seep up through the floor when the washer drains.
It only smells for 5 minutes at a time when we drain then smell goes away, but no, we have not capped the vent overnight
Smoke testing the DWV lines is the smartest way to go at this juncture.
