Sewer Crock Installation Concern
ClarksonCote
May 1, 2023
New York, USA
HI everyone,
15 years ago, the builder for my house installed a sewer ejector crock in my basement, for a half bath rough-in. I'm finally working on finishing my basement and plan to just use this for the washing machine. Opening this thing up for the first time, and the pictures below are what I found.
My concerns:
  • I would've expected the PVC pipe to go INTO the crock, and not terminate just prior to it.
  • I'm also surprised looking into the pipe, there are a lot more breaks in the pipe than I would've expected. Maybe that's just a bunch of couplings but it seems suspect.
Since this is just for a washing machine, is using some silicone caulk around that point of entry sufficient? Is some piece missing that I just need to go buy to get the pipe into the crock? Any thoughts on the amount of breaks in the pipe that's under the concrete?
Thanks in advance.
    765 KB
    648.5 KB
    931.6 KB
    685.4 KB
Why don't you run a hose into one of the drains connected to it and see what happens, one of those couplings you see is not a coupling it's a ty or wye silicone will not work for fixing leaks
Thanks for the reply. The pipe under the floor seems okay, I think those are just fittings as you point out. I know where all the pipes run. The main concern is that the pipe doesn't really go "into" the crock, as you can see in the pictures (IMG_2102, IMG_2104). It appears as if there's a gap there, though maybe it's a poorly designed flange and the crack with dirt in it really is sealed from the subfloor of the basement.
