S trap situation and air admittance valve?
rmflint
Jan 4, 2024
Florida
This is a picture of the drain plumbing under my kitchen sink. I have been noticing sewer smells inside our cabinets. I removed and cleaned the p trap pipes and they were not dirty. The sink drains fine.
I am thinking the way it hooks up to the septic drain line has created an s-trap situation.
The drain pipe is vented through the roof behind the wall.
Would adding an air admittance valve (AAV) be a recommended solution?IMG_9352.jpeg
Yes. to note: Code requires kit. sink drains to be 2". and drainage fittings to be used...what i see is a elbow made for pressure pipe and no required cleanout. Idiots who are not plumbers did this work so there you go.
