HHHHat
I replaced the seats and springs to fix a leak from the tub spout (2 handle, wall mount with shower). After about 2 weeks, the drip started again.
Thing is, the old springs were about 1/64” longer and less “springy” than the replacement springs. The seats looked identical. Maybe the pressure against the seats isn’t enough with shorter springs?
I got the set for Delta because they looked the same in the package, but I don’t know what brand ours actually is. There are no logos or model numbers, and the fixtures came with the house (22 years ago).
I ordered an assortment of replacement spring/seat sets for different brands that looked promising, but none of those match the old springs, either.
Can I custom order springs that might match my setup? Or can I MacGyver something so the spring’s length & firmness is right? Would twisting two Delta springs together to get the right length work?
I’d get a new faucet set, but the pipes are deep behind a tiled wall, and from what I can tell, would mean pipe work to fit the length of standard-mount fixtures. Too much for my skillz...
