plumbnewb645
Hello, I purchased two bidets for my toilets at home. Was able to install one without issue, but am running into a glued hose attached to the water valve coming from the wall. I have a metal braided cable I want to replace it with.
What is the correct way to remove a glued hose? Do I need to get a heat gun to soften up the glue?
Will post a photo when able
