Hi guys, I am remodeling our kitchen and when I removed the cabinets i discovered the dirty arm was notched into the back of the cabinets. I would like to put it into the wall. instead of notching new cabinets. I understand the basics, cut out old fitting, hole saw through studs, put in new dirty arm and stub out.. Can someone PLEASE explain to me how do i reattach the vent to the waste line.. can I use a Fernco flexible coupling or is there some way to getting a regular hard coupling in there. Also I will be putting in an apron sink, and I understand that due to the depth of the bowl sometimes people have problems using a garbage disposal if the waste line stub out is not low enough,, My question is I know that there is a maximum height u can stub out the waste line, but is there a minimum? cant i just run my new plumbing as low as possible to make sure i don't encounter any problems with the garbage disposal. thank you!! -Rob
